WPAWS Posted July 10, 2017 Share Posted July 10, 2017 reading the forums i have found out about what my 2008 (57) - Audi A6 3.0 TDI sline Le Mans Quattro can do which i never knew before like holding the unlock button down on the key fob will open the windows and the same holding the button down when locking the car will close the windows :) i`ve yet to try the passenger mirror pointing down when reversing as i cant find the post again. are there any other tricks or tips i may be missing out on Quote Link to comment Share on other sites More sharing options...
Sven Posted July 10, 2017 Share Posted July 10, 2017 The passenger mirror tilt is only activated when you have it in set mirror (passenger) and you maybe have to activate it whit the computer as not all of them have it from factory set. 1 Quote Link to comment Share on other sites More sharing options...
WPAWS Posted July 10, 2017 Author Share Posted July 10, 2017 Cheers Sven :) Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted August 8, 2017 Share Posted August 8, 2017 On 7/10/2017 at 4:16 PM, Sven said: The passenger mirror tilt is only activated when you have it in set mirror (passenger) and you maybe have to activate it whit the computer as not all of them have it from factory set. This works only on facelifted models and requires coding It can be done on pre facelift but requires door modules change and coding Quote Link to comment Share on other sites More sharing options...
Sven Posted August 8, 2017 Share Posted August 8, 2017 3 hours ago, niedzial1983 said: This works only on facelifted models and requires coding It can be done on pre facelift but requires door modules change and coding Try to activate it on my A6 with vcds but it does not come up strangely... a5 was no problem and I thought that a6 would have it definitely build in. You might be right with door modules! Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted August 8, 2017 Share Posted August 8, 2017 8 minutes ago, Sven said: Try to activate it on my A6 with vcds but it does not come up strangely... a5 was no problem and I thought that a6 would have it definitely build in. You might be right with door modules! On a6 c6 yes . New moduls are required , i can dig out what part numbers they are if anyone is intested Quote Link to comment Share on other sites More sharing options...
Sven Posted August 8, 2017 Share Posted August 8, 2017 38 minutes ago, niedzial1983 said: On a6 c6 yes . New moduls are required , i can dig out what part numbers they are if anyone is intested C7 Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted August 8, 2017 Share Posted August 8, 2017 19 minutes ago, Sven said: C7 Not sure about c7 . This part of the forum is about c6 Quote Link to comment Share on other sites More sharing options...
Sven Posted August 8, 2017 Share Posted August 8, 2017 Ok no worries... Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted August 8, 2017 Share Posted August 8, 2017 2 minutes ago, Sven said: Ok no worries... Here you go mate All tricks for c7 . http://www.vwaudiforum.co.uk/forum/showthread.php?t=132245 1 Quote Link to comment Share on other sites More sharing options...
Lanky111 Posted August 9, 2017 Share Posted August 9, 2017 needle sweep - no idea why by I love this 20170721_092326.mp4 1 Quote Link to comment Share on other sites More sharing options...
