audi-all-the-way Posted July 11, 2017 Posted July 11, 2017 Genuine VAG COM VCDS Available to use for a small fee 00 Auto-Scan 01 Control Unit Info 02 Read Fault Codes 03 Output Tests Selective Output Tests 04 Basic Settings 05 Clear Fault Codes 06 Close Controller 07 Code Module Code Slave Modules 08 Measuring Blocks 09 Single Reading 10 Adaptation 11 Login (called Coding II under KWP-2000) 15 View Readiness 16 Security Access 18 Supported Codes 33 Generic OBD-II Freeze-Frame Data Dual K-Line Support 7-Digit PINs (VAS only) Code Database current through MY 2012 Diagnostics via direct CAN connection Transport Mode (VAS Only) Advanced Measuring Values Guided Readiness Scripts Support for Dual ECUs Data Logging (Factory tools cannot do this!) HighSpeed DataLogging (Factory tools cannot do this!) Real-Time Graphs (Factory tools cannot do this!) Real-Time Gauges (Factory tools cannot do this!) Graphic TDI Timing Checker (Factory tools cannot do this!) Control Module Finder (Factory tools cannot do this!) Automated Service Reset (SRI) ECU Mileage Checker
