Help wanted with VAGCOM fault codes
scal
Hi All,
I've run a scan on my "new" Audi A3 and have recovered the following fault codes. I have the Engine Management light on on the dash so I know there is an issue with the engine faults, however I dont want to change evergything! Does anyone have any suggestions as to:
1 - how to work out what the fault codes are exactly (Ross-Tech site wasn't very helpful here and not all the codes give a description!)
2 - Apart from the engine faults, how important are the others?
Thanks!!
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-906-056-AXW.lbl
   Part No SW: 06F 906 056 BT    HW: Hardware No
   Component: MED9.5.10        00 5340
   Revision: 00000000    Serial number: AUX7Z0C6FNT0HQ
   Coding: 0000072
   Shop #: WSC 06435 000 00000
   VCID: 7CF792D53F3AF4A193-8028
   Subsystem 1 - Part No: 06F 907 807 A
   Component: NOX  0307300042 004 3608
   06F907807A  NOX  0307300042 004 3608
12 Faults Found:
18354 - Control Module 1 for Coolant Fan
            P1946 - 004 - Defective - Intermittent
17833 - Unlicensed Version. Not all DTCs
            P1425 - 002 -  - Intermittent
17935 - Unlicensed Version. Not all DTCs
            P1527 - 002 -  - Intermittent
17923 - Intake Manifold Valve (N156)
            P1515 - 002 - Short to Ground - Intermittent
17702 - Unlicensed Version. Not all DTCs
            P1294 - 002 -  - Intermittent
18068 - Unlicensed Version. Not all DTCs
            P1660 - 002 -  - Intermittent
17441 - Sensor for NOx (G295)
            P1033 - 002 - Signal too Low - Intermittent
16575 - Unlicensed Version. Not all DTCs
            P0191 - 008 -  - Intermittent
17811 - Unlicensed Version. Not all DTCs
            P1403 - 008 -  - MIL ON
16825 - EVAP Emission Control Sys
            P0441 - 008 - Incorrect Flow - Intermittent
17439 - Unlicensed Version. Not all DTCs
            P1031 - 004 -  - Intermittent
18322 - Unlicensed Version. Not all DTCs
            P1914 - 002 -  - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043     HW: 8P0 820 043
   Component: KlimavollautomatH11 0130
   VCID: 69D9DB8140A8710978-803C
3 Faults Found:
01592 - Air Quality Sensor (G238)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 21
                    Reset counter: 114
                    Mileage: 94266 km
                    Time Indication: 0
                    Date: 2017.03.09
                    Time: 10:05:30
             Freeze Frame:
                    Temperature: 18.5°C
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 39
                    Reset counter: 77
                    Mileage: 94249 km
                    Time Indication: 0
                    Date: 2017.03.02
                    Time: 11:03:36
             Freeze Frame:
                    Temperature: 9.0°C
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 100
                    Mileage: 131072 km
                    Time Indication: 0
                    Date: 2032.00.00
                    Time: 00:00:00
             Freeze Frame:
                    Voltage: 6.80 V
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H27 0401
   Revision: 00000000    Serial number: 00000000108020
   Coding: 018C4F00A0141000000000000000000000
   Shop #: WSC 00000 000 00000
   VCID: 3B7551C97AB43399DA-806E
   Subsystem 1 - Part No: 8P2 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
   Shop #: WSC 00000
3 Faults Found:
01320 - Control Module for Climatronic (J255)
            004 - No Signal/Communication - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
00446 - Function Limitation due to Under-Voltage
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433
   Component:    KSG          H02 0040
   Coding: 008800186D288505485AC63000
   Shop #: WSC 00089 210 12751
   VCID: 79F98BC13008C18988-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  002 0002
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H01 0010
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Unlicensed Version. Not all DTCs
            004 - will be decoded. - Intermittent
01134 - Unlicensed Version. Not all DTCs
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H52 0060
   Revision:      05S    Serial number: AUZ2Z3C1317541
   Coding: 0001001
   VCID: 6FEDB5997E4C9F3926-803A
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 100
                    Mileage: 95526 km
                    Time Indication: 0
                    Date: 2017.05.14
                    Time: 00:00:42
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 104
                    Time Indication: 15
             Freeze Frame:
                    Bin. Bits:       10
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 104
                    Time Indication: 15
End-------------------------(Elapsed Time: 01:43)--------------------------
VAGCOM_Faults.txt
I am new to using these diagnostic tools, so the output posted above is what it returned before clearing any fault codes. I cleared them all recently and have done a few hundred miles since.
Focusing only on the engine faults (I'm not too worried about the rest... yet), today it returned 3 faults before clearing any fault codes and then only 1 fault after clearing the codes and re-running straight away.
Before clearing DTCs:
3 Faults Found:
17811 - EGR System
P1403 - 008 - Regulation Deviation - MIL ON
18322 - Pressure Sensor for Brake Boost (G294)
P1914 - 002 - Implausible Signal - Intermittent
17480 - NOx Sensor (G295) Heater Control
P1072 - 008 - Circuit Malfunction - Intermittent
Readiness: 0000 0100
Straight after clearing them and re-running:
1 Fault Found:
17811 - EGR System
Readiness: 1110 0101
What I do not understand now is whether the only actual fault I have is the EGR? I assume from what I have read that I need to either replace the EGR valve, just clean it and replace it or get a removal kit. The question is whether the "intermittent" fault codes for brake boost and NOx are an actual issue or just unhelpful errors due to the EGR valve? Any help much appreciated, thanks!
I think NOx will be related to EGR function or lack of.
You did right clearing that massive list of codes, I bet that they were caused by the ignition being on when many electrical plugs were disconnected at some stage.
it will be worth removing and cleaning the EGR. Go from there.
  • 4 months later...
As a follow-up to this, the EGR was the problem. Some teeth of the cogs had sheared off (probably due to perished plastic - don't know why they build such an expensive item using parts which cannot individually be replaced... oh wait I know why!).
It is possible to lift off and rotate the central cog, however this fix only lasted a few days before it sheared the teeth off the "quarter" cog underneath. I managed to purchase a brand new unit on eBay for £80 which is quite cheap considering what Audi will charge... Now I just have to fit it and hope for the best.
