Sam Parker Posted August 18, 2017 Posted August 18, 2017 Hi, have an 03 a4 convertable. The roof opens with no issues. If I stop 3/4 the way and close it there is no problem. If I completely open it then try to close it , the lid will open,I can here the hyadralic motor try to open the roof twice then the third time the roof move about 1/2 and inch then it stops and i have to close manually. Why ideas? Sam
WPAWS Posted August 18, 2017 Posted August 18, 2017 6 hours ago, Sam Parker said: hydraulic motor Sounds to me you found the fault already m8 have a garage check it over could be the motor is on its way out
Sam Parker Posted August 22, 2017 Author Posted August 22, 2017 Thanks Paul, does the control module stop trying the motor if but does start to move then.
jonbrightonA4 Posted November 1, 2017 Posted November 1, 2017 easy fix im non mechanical and replaced it in 85 mins auto electron uk have a great step by step guide as they tell you how to remove and send off for repair i just replaced it ,took my 85 mins start to finish
Sam Parker Posted November 1, 2017 Author Posted November 1, 2017 1 hour ago, jonbrightonA4 said: easy fix im non mechanical and replaced it in 85 mins auto electron uk have a great step by step guide as they tell you how to remove and send off for repair i just replaced it ,took my 85 mins start to finish What did they replace?
jonbrightonA4 Posted November 1, 2017 Posted November 1, 2017 i bought a new pump with motor on Ebay £150 ,once i read the detailed instructions for removal from autoelectron i decided to pull out the old unit then swap just the motor that was it fixed .. Removing whole pump with motor attached is 3 bolts then its just 2 bolts to switch over the motor
