Alex87 Posted August 22, 2017 Share Posted August 22, 2017 Good evening all, Just wanted to share my latest scan with yourselves and ask you a couple of questions. I've performed a full scan (I was only trying to find a faulty parking sensor) and came across all these faults. The really concerning ones are the ones on the: 1. Battery regulator - checked the battery level on MMI and it was at 100% with no issues 2. Potentiometer - can I just order a new one and replace instead of cleaning it? 3. Some of those bulbs are actually working but still coming up as an error - just replace them with new ones? 4. Can anyone give me the part number for the sensor and if anyone recommends a good place to buy them from would be great. Thanks in advance. Audi A6 C6 .txt Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted August 22, 2017 Share Posted August 22, 2017 My recomendations :) 1. Battery regulator - checked the battery level on MMI and it was at 100% with no issues ###clear the error and see if it comes back as its intermitent 2. Potentiometer - can I just order a new one and replace instead of cleaning it? ### potenciometer is build in in to central 2 vent unit , whole unit needs to be replaced. Mine broke 2 years ago and its not cousing any issues , i can send you more info on this tomorrow .Look at this on eBay http://www.ebay.co.uk/itm/132280456443 3. Some of those bulbs are actually working but still coming up as an error - just replace them with new ones? ### Common fault . Take the rear lights out , clean all connectors and plugs etc and spray some contact cleaner . Problem is bad earth . If its not helping then you need to twist the earth pin so its sitts better in the plug. Let me know i can send you picture where as it sorted my lights issues Quote Link to comment Share on other sites More sharing options...
Alex87 Posted August 28, 2017 Author Share Posted August 28, 2017 Hi all, Done a bit of work on the car today and cleared all the errors...the only one that still came back is the sensor, which is almost always causing an issue. Can anyone recommend where to order a new parking sensor or a part number so I can start searching for a new one? Thanks in advance. Log-SH06VWE-WAUZZZ4F96N177106-153170km-95175mi.txt Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted August 28, 2017 Share Posted August 28, 2017 Good news with the scan eBay might be ypur best bet but it needs to be painted to match your colour . http://www.oemepc.com/audi/part_single/catalog/au/markt/RDW/modell/A6/year/2006/drive_standart/448/hg_ug/919/subcategory/919020/part_id/275945/lang/e Quote Link to comment Share on other sites More sharing options...
Steve Q Posted August 28, 2017 Share Posted August 28, 2017 Welcome to the forum Alex :) glad non of the other codes came back. With regard to those errors Piotr gives very good advice :) cheers steve Quote Link to comment Share on other sites More sharing options...
Alex87 Posted September 3, 2017 Author Share Posted September 3, 2017 Thanks Steve. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted September 3, 2017 Share Posted September 3, 2017 1 hour ago, Alex87 said: Thanks Steve. Your welcome :) Quote Link to comment Share on other sites More sharing options...
