hi all I have a q5 2013 with the 7 speed s tronic gearbox wich  came up with gearbox overheating adapt driving then went straight out it done this a few times and now in the garage with burnt oil and have been told its due to wear and tear off the clutch pack.... gearbox oil and filter first done at 40670 mils and then again at 77460 mls  and is currently  on 106000 ..so isn't due another gear oil change as yet any help to why the clutch plates are worn thanks all
Had a 3.0TDI 09' with 125K miles on it gearbox was replaced under warranty 18K miles (knocking noises) from new after that I know its not much help, but totally solid performance and awesome gearbox oil and services was steady totally as you'd expect from the book. again not much help just wanted to say know a few Q5 owners 2 with 2L TDI and 2 with SQ5's none have excessive servicing/oil/gearbox issues...
