Hi all
i have noticed on my a8 the auto door locking feature when you pull away doesn't always lock the front doors as I especially notice the little red light between the lock/unlock buttons on door is not lit up. Other times the red light is lit up indicating the door is locked.
anyone else experienced this? Please and is there a reason or solution? As I find this feature useful and a good security measure.
many thanks
Hey mark, sorry to hear your having issues with your a8.
By any chance havenyou got vagcom? I ask as I believe in other Audi models the auto lock feature could be programmed in at a later date. IM telling you this as the system may just need resetting.
In failing that I would suspect a sensor has failed that tells the car when to lock.
Your best bet is to get it plugged in for a diagnostic check if you haven't got vagcom.
Hope iv helped
cheers
steve
Thanks for your reply Steve.
now I'm going to sound dumb but what is vagcom? And can I do a reset myself to see if that will fix the problem?
regards
mark
regards
mark
Your welcome :)
Vagcom is a basic form of diagnostic equipment you can buy. It can cost up to £300 for the all singing all dancing versions (like rosstech) but I believe it can be bought for less than £100 but don't quote me on that.
quite a few other members have it abd have found it useful to find out fault codes and reset certain features on their Audis :)
hope iv helped :)
cheers
steve
