WelshSue Posted September 19, 2017 Posted September 19, 2017 I have noticed that my N/S rear disc brake backplate has rusted through & flapping about. The O/S one is not as bad. Do they actually serve a purpose or can I remove them?
niedzial1983 Posted September 19, 2017 Posted September 19, 2017 Quite a few . Protects suspention elements from heat, dust, water splashing etc Just get a replacment , i cant imagine this being expensive
Steve Q Posted September 19, 2017 Posted September 19, 2017 I agree with Piotr just replace it. Iv never heard of this happening though and my a6 has covered 328,000 miles!
Magnet Posted September 19, 2017 Posted September 19, 2017 Hello Susan, Yes, it has to be replaced. The part is not too expensive as I recall, but I believe it is a main dealer part only. Should be available with a bit of discount by talking nicely in Welsh! Yes, these simply painted mild steel parts do rust and bits fall off them. Not uncommon, and it's usually the N/S goes first ad you would expect. Kind regards, Gareth.
WelshSue Posted September 19, 2017 Author Posted September 19, 2017 Thanks for the replies Guy's. I've had a look on the interweb. Seller on eBay had them for £59.99 for the pair, but thought I'd check elsewhere & found them on Amazon for £38.44 for the pair + £3.99 p&p. Should be here in the next few days. Looks fairly easy to fit(looking at Elsawin) Brake caliper off,Disc off, remove ABS sensor then unbolt hub. 1
Magnet Posted September 19, 2017 Posted September 19, 2017 Think the last one I had for the A3 via. Audi was a bit under £20 from memory. Good to know they are available as aftermarket parts for the A6. Kind regards, Gareth.
WelshSue Posted October 4, 2017 Author Posted October 4, 2017 Took rear N/S wheel off yesterday to replace the splash guard. Couldn't get the Hub bolts off as completely seized on. What was left of splash guard fell off!! Going to take to local garage for them to see if they can get the bolts out.
Steve Q Posted October 4, 2017 Posted October 4, 2017 Oh no! Not good! Hope it gets sorts quickly for you!
Magnet Posted October 4, 2017 Posted October 4, 2017 Hello Sue, Well that makes the ones which I change on the A3 look pretty good! In the first photo, it appears to show a pair? of brake pipes clipped to the suspension arm. The nearest one seems to be rustier than you would like. Wondered if this has been carefully examined. Kind regards, Gareth.
WelshSue Posted October 4, 2017 Author Posted October 4, 2017 2 hours ago, Magnet said: Hello Sue, Well that makes the ones which I change on the A3 look pretty good! In the first photo, it appears to show a pair? of brake pipes clipped to the suspension arm. The nearest one seems to be rustier than you would like. Wondered if this has been carefully examined. Kind regards, Gareth. Both pipes are fine,It was just a build up of dirt. Used a stiff brush then washed it off,dried & smeared with vaseline
