Audi vagcom/vcds
username
Hi all, can someone please suggest where to get a useful (I.e one that can read transmission/abs codes too and measuring blocks) vcds in the uk? Not the cheap ones off eBay. Car in question is an 05 Audi A6. Thank you.
3 hours ago, niedzial1983 said:
Carista and obdeleven will show faults not much else
Whats wrong with your a6?
Which faults will it show? It's not like measuring blocks is it?
its an auto multitronic gearbox and keeps getting stuck in park. I want to see the brake pedal switch readings in measuring block so see if it is functioning ok or if it's the f125 switch then hopefully that will give an error code?
