Hi All,
having seen those led puddle lights on fleabay I realised I had never seen any light emenating from the underneath of my doors.
I checked today and yep, there are underdoor light modules on each door but neither illuminate!
I don’t have the upgraded LED package, so am unsure if the front footwells should also be illuminated and are also faulty / not programmed to be on.
Question:
Whats the best easiest and quickest way to check that they are meant to be on & should my footwells also be lit up when getting in and out?
cheers 👍🎯
They were on but really dim.
Turned up the welcome lights via the MMI.
STILL LOW LIGHT WHEN ON HIGH!
So buying the Audi upgraded LED puddle lights.
  • 3 months later...
Changed all 4 door puddle lights to the Audi rings - bought from Audi via eBay for £50 per 2 pack.
Highly recommened over the factory fitted puddle lights.
i brought the sline ones, done the front 2 fine but lost the cable back up in the door on my rear one, will need to take door panel off the retrieve the connector lol thats a job for spring or summer :thumbup:
