T3RRY Posted October 7, 2017 Posted October 7, 2017 Hi, just joined so thought I would introduce myself! First Audi and so far I am pretty pleased with it. The CD multi changer is not lighting up? Its in the glovebox (2007) model? Is there a specific fuse for this? Regards T3rry
WPAWS Posted October 7, 2017 Posted October 7, 2017 Welcome to the forums Nice friendly atmosphere here with plenty of Audi owners to help where they can not sure about the cd not lighting up but if a fuse is gone i would say its in the fuse box on the passenger side Paul
Steve Q Posted October 8, 2017 Posted October 8, 2017 Welcome to the forum Terry :) You'll find d the members on here are a friendly and helpful bunch :) I'd say if the radio is still working then it could be a bulb within the radio that's at fault. Cheers :) Steve
niedzial1983 Posted October 8, 2017 Posted October 8, 2017 If the radio is still working then i means cd changer is connected . A6 c6 audio works on fiber optics connection called MOST , it could be no power to the cd changer or cd changer is dead . There is no dedictated fuse for cd changer only so if everything else is working then its safe to assume the fuse is fine. Best is to take it out and check with mulitmeter if there is power in the plug Also if someone messed up with the cd changer it could be componet protection triggered . Do a vcds scan to check . CP removal requirers special tools that audi only have ( i think its £70 to remove ) Hope this makes sense :)
T3RRY Posted October 8, 2017 Author Posted October 8, 2017 Thanks guys for the welcome and the advice The radio and MMI are all working fine just cant load the cd unit. Tha Sat Nav next to it is lit up but no light on the CD? I have been going through the forums looking at relevent posts Some really good advice and you lads know your stuff! This VCDS scan sounds the way to go. I was going to book it in for a diagnostic at an independent they want £50 ? Is this the same thing? Regards T3RRY
niedzial1983 Posted October 8, 2017 Posted October 8, 2017 Should be the same . Just ask for a faults scan and print out Dvd satnav in thr glove box ? Unusual , normaly dvd unit is in the boot. Send us a pic of your glove box
Steve Q Posted October 8, 2017 Posted October 8, 2017 44 minutes ago, T3RRY said: I have been going through the forums looking at relevent posts Some really good advice and you lads know your stuff! Your welcome and thank yu! We definitely try and help.where we can :) As Piotr has said a pic of the glovebox will.help a d I have to agree with him that a diagnostic check might not be a good idea. Like I say though and if it's possible, could it be a blown bulb? Cheers Steve
T3RRY Posted October 8, 2017 Author Posted October 8, 2017 It is CD multichanger and SatNav side by side in the glove box The red light is on the SatNav but nothing on the CD changer It is the MMI basic I think No SatNav disc yet It is the red screen MMI unit
niedzial1983 Posted October 8, 2017 Posted October 8, 2017 Yep mmi 2g basic plus as you have dvd sat nav as well
Trevor Posted October 9, 2017 Posted October 9, 2017 Hi Terry...welcome to the Forum Good to have you onboard Cheers, Trevor
T3RRY Posted October 9, 2017 Author Posted October 9, 2017 Thanks for the welcome Trevor Still trying to get through some of these forums topics! Also keep pressing different buttons on the MMI trying to get used to it ! ! ! Hope to have most of it sussed by weekend 1
