Ive been having problems with my auto audi a4. It kind of slips at low speeds but no power is getting to the wheels.like when clutch slips on a manual car.the garage i bought the car from are thinking it may be down to the torque converter?.has anyone else experienced this problem. What price am i looking at for a fix as my warranty only covers up to £300
Welcome to the forum Craig :)
You'll find the members on here are a friendly and helpful bunch :)
As piotr.has asked we need to know what engine you have and what gearbox you have so in order to give you more accurate info :)
Hi its 2007 2l tdi s-line BRE engine code whats the difference between tiptronic and multitronic
6 minutes ago, Craig hill said:
Also thanks for welcoming me to the group
You're welcome :)
2 minutes ago, Craig hill said:
Ive seen on some forums it could be a problem with the transmission fluid
Do you.know when the fluid was last changed?
No steve i dont ive only had it 4 months. I changed engine oil and filter a few weeks ago but no history of transmission fluid change. I must add i am a mechanic steve but not much knowledge of autos tbh
The symptomi was getting was what people wer decribing as torque converter judder
Tip is 6speed , multi is 7speed
12 minutes ago, Craig hill said:
Its multi then mate ye 7 speed
Without a proper diagnostics its imposible to advise. A gearbox specialist should be able to advise .
Google about issues with audi multitronic boxed . There is lots of topics ... like this one
 https://www.audiworld.com/how-tos/a/audi-a4-b8-multitronic-cvt-problems-421233
 Multitronic needs oil changed every 40k if not then it can be an expensive fix
One thing i can advise if you will decide to fo any repairs , hold off with oil change as it will be drained off as part of the repair anyways
Ok mate thanks the car is already at the garage they are trying to diagnose the problem i just dont want to be ripped off...could the torque converter itself break?
Hi people the garage changed my tranmission fluid and filter and is still the same. Next thing they are saying is dual mass could be gone and quoted £670😠😠has anyone else had dual mass go
  • 2 years later...
Hi. Old thread I know, I apologies.
Just wondering if there was an answer to this issue.
I've similar experience with my 08 B8 V6 tdi Avant s-line 8 speed.
The box is undecided as to what gear it wants to be in, worse when cold and in D.
8 speed, flappy paddles and manual control.
Going to a specialist on Tuesday but would like more knowledge before then. Searching Google seems very conflicting.
