PMH Posted October 9, 2017 Share Posted October 9, 2017 Hi all, 2010 A6 Le Man 2.0TDi I have been having some issues with the emissions control warning light coming on. The garage suspect a dodgy sensor and have added some DPF cleaner to the fuel to help the situation? When I checked the fuel filler earlier I could see straight down the fuel pipe. I am sure there used to be a flap across the neck of the filler. Should there be one? As anyone else got a flap across the filler pipe? I wondered if this might be part of the problem? Thanks Paul Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted October 9, 2017 Share Posted October 9, 2017 2006 3.0tdi , no flap . Quote Link to comment Share on other sites More sharing options...
PMH Posted October 9, 2017 Author Share Posted October 9, 2017 Ah ok, maybe I am just going mad. Thanks a lot. Engine warning must be something else. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted October 9, 2017 Share Posted October 9, 2017 Welcome to the forum Paul :) You'll find d the members on here are a friendly and helpful bunch :) What kind of driving g are you doing? I ask as I'm wondering whether the dpf is able to do it's regeneration cycle properly. Wgat garage are you using? I too live in leicestershire and use AC motor services in Syston. Brilliant garage and very knowledgeable. Please note I have not links to them bar them fixing and servicing my a6. Cheers Steve Quote Link to comment Share on other sites More sharing options...
PMH Posted October 10, 2017 Author Share Posted October 10, 2017 Thanks for the reply. I am mainly town but do a weekly longer drive. The dpf seems to regen as every so often the fan runs after turning the engine off. Also the revs seem a bit higher in idle every so often. I take it to Tanvic in Loughborough as they have always looked after me. They suspect the first sensor before the DPF? Will investigate a bit more although it drives fine! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted October 10, 2017 Share Posted October 10, 2017 Well replacing g the sensor will.be a cheaper start than replacing the dpf! Keep us posted on how you get on :) Cheers Steve Quote Link to comment Share on other sites More sharing options...
