Hi,
my car is an Audi B5. A4 tdi avant, 1999.. facelift model..
the problem is as follows:
Simptoms:
1. Front speakers are a lot louder than rear
2. Trunk stock bass speaker works when volume low. When slightly increasing
volume the bass dissapears..
Its a non bose system, with 2 front speakers with tweeters, 2 rear door speakers, and an amp with bass speaker in the left wall in the trunk behind the panels..
So my question is: do I need to replace the amp??? Headunit?? Or speakers. ???? Where lies the problem ??
thanks allot!!
I presume your sound settings are set correct balance fader front back etc ?
Is it an oem audi system or aftermarket ?
Yes, its set correctly,  its a stock concert 1, with tape..
  • 4 weeks later...
Hi
Have you taken the head unit out and made sure all connections securely in?
