Steven23 Posted October 31, 2017 Posted October 31, 2017 Hello everyone, I'm new to the forum / website as I've only just got an A4 cab, I had a 2000 TT quattro before so this is a bit like driving a bus especially as its an auto !. Lots of little faults but working my way through them bit by bit. I thought I would upgrade the Satnav so I bought a new disc, tried to eject the old disc but nothing happens, no whirring or anything which is odd. I've ordered a set of four keys to remove the whole unit hoping there is a manual eject somewhere on the body of the unit. If anyone has a clue how to eject the ROM disc when the eject button fails to work I would be really pleased to know !. Once I've cracked that its onto the non beeping reversing sensors. The car just makes one long beep when going into reverse which I know is a bad sign, I listened to the sensors and only one is clicking so I guess its either three duff sensors or a duff unit, who's location I have yet to track down. I believe I will have to remove the complete bumper / boot liner to get at them so thats a job for a full weekend, annoyingly I know I will have to do the job twice, once to spot the issue and once when replacing the sensors / unit ...but I bought the car with these faults at a good price knowing they can all be fixed !. I've yet to find out if its a factory fitted sensor system, suspect if may be after market. Anyway do drop me a line back and say hello to me stuck up here in the frozen north ...well Halifax anyway !
Steve Q Posted October 31, 2017 Posted October 31, 2017 Welcome to the forum Steven :) You'll find the members on here are a friendly and helpful bunch :) Sounds like you've got an interesting project there! Cheers Steve
Audi Owners Club. Posted November 1, 2017 Posted November 1, 2017 Hi Steven....welcome to the Forum The sensors aren't too expensive from eBay and also it should be too bad to remove and refit the bumper...I would probably fit all three but carry out a resistance check to compare to the one remaining good one. Good to have you onboard Cheers, Trevor
niedzial1983 Posted November 1, 2017 Posted November 1, 2017 21 hours ago, Steven23 said: thought I would upgrade the Satnav so I bought a new disc, tried to eject the old disc but nothing happens, no whirring or anything which is odd. I've ordered a set of four keys to remove the whole unit hoping there is a manual eject somewhere on the body of the unit. If anyone has a clue how to eject the ROM disc when the eject button fails to work I would be really pleased to know !. Its factory locked. The eject button is disabled. You need vcds to enable
niedzial1983 Posted November 1, 2017 Posted November 1, 2017 21 hours ago, Steven23 said: Once I've cracked that its onto the non beeping reversing sensors. The car just makes one long beep when going into reverse which I know is a bad sign, I listened to the sensors and only one is clicking so I guess its either three duff sensors or a duff unit, who's location I have yet to track down. I believe I will have to remove the complete bumper / boot liner to get at them so thats a job for a full weekend, annoyingly I know I will have to do the job twice, once to spot the issue and once when replacing the sensors Yes that will be broken sensors. You can check by listening for a click on reverse or if you hold your finger you will feel a pulse on the one that is working . Another way is to do a vcds scan for faults that will tell you . Its bumper off to swap and test before the bumper goes back in ! :)
Steven23 Posted November 1, 2017 Author Posted November 1, 2017 Yup I had already listened to the sensors and found 3 duffers, do you know where the main unit they run back to is located as I don't fancy ripping the entire boot liner out only to find its up front somewhere !
Steven23 Posted November 1, 2017 Author Posted November 1, 2017 3 hours ago, niedzial1983 said: Its factory locked. The eject button is disabled. You need vcds to enable I'm spitting feathers over this as it seems the dealers do this to stop folk pinching the ROM disks but should unlock them before delivery, apparently thats why the previous owner never upgraded the disk !. I suppose I have to fork out for Audi to do the job and suck it up.
niedzial1983 Posted November 1, 2017 Posted November 1, 2017 2 hours ago, Steven23 said: Yup I had already listened to the sensors and found 3 duffers, do you know where the main unit they run back to is located as I don't fancy ripping the entire boot liner out only to find its up front somewhere ! Get a vcds scan in a local garage . It will show if its sensors or module
Steven23 Posted February 2, 2018 Author Posted February 2, 2018 I actually fell out with the A4 and chopped it for another TT roadster the MKII version this time !. Satnav ejects okay, reversing beepers work but the heated seats don't work !! I love a challenge, I've metered the seats and looks like the wiring makes a circuit so it could be the power to the seats as the 25 amp fuse is okay it could be somewhere else. I wonder if they have heating controllers on these seats like the Volvo's ?? if so the issue may be there, just odd that its both seats on all three heat settings though. They did work for a while when we bought the car as driving home they were fine then the next day nothing !
