Diggy98 Posted November 13, 2017 Posted November 13, 2017 Hi, today I noticed a nasty squeaking noise when turning the wheels to the max (both left and right). Fluid level is ok but i have never changed it since i bought the car (3 months ago). Could the fluid be the problem or should I be looking for a new pump?
Steve Q Posted November 13, 2017 Posted November 13, 2017 Hi Dragos, It could be the pump of the pulley. When I had this issue it was because if the pulley. Obviously the cheapest and easiest option is to change the fluid first. Cheers Steve
Diggy98 Posted November 13, 2017 Author Posted November 13, 2017 Thank you Steve, will do the fluid change asap. Do you know how much fluid is needed for the job? I guess it shouldn't be more than 1 litre, am I wrong?
Steve Q Posted November 13, 2017 Posted November 13, 2017 51 minutes ago, Diggy98 said: Thank you Steve, will do the fluid change asap. Do you know how much fluid is needed for the job? I guess it shouldn't be more than 1 litre, am I wrong? Yea I wouldn't say much than a litre but it should be in your manual. In failing that I've found this video which will help.you change the fluid :) Cheers Steve :) 2
Diggy98 Posted November 13, 2017 Author Posted November 13, 2017 Don't have the manual...will look for a pdf on the internet. Thank you very much for your help!
Steve Q Posted November 13, 2017 Posted November 13, 2017 1 minute ago, Diggy98 said: Don't have the manual...will look for a pdf on the internet. Thank you very much for your help! That's alright hope the video helps :)
