AudiMickey Posted November 26, 2017 Posted November 26, 2017 Hi All, I have recently replaced these (and yes the adjustable bolts are a B**ch to get out)!! However i now need to track the vehicle so that i can drive it to the garage in order to get it tracked properly. (slight oversight on my part as I didnt think about the tracking until after i had replaced them!) Any ways i have now took it off my ramp and took it on a drive and by gosh its all over the place, is there any "tricks of the trade to get these arms even remotely tracked up? or do i need some witchcraft? Thanks in advance for any help and suggestions!
cliffcoggin Posted November 26, 2017 Posted November 26, 2017 You can get them approximately aligned with the front wheels by clamping a length of straight wood against the rims and adjusting the toe in visually. You will probably need to use spacer blocks to clear the tyres. Bounce the suspension a few times after adjustment, then check again.
