Brad-B5 Posted November 27, 2017 Posted November 27, 2017 Hi All I have done one similar to this but I wanted to know what are the common issues on the 2008-2010 Petrol A5? Any particular mileage I should look out for that might bring some issues with it? Thanks for you info :) Regards Bradley
Steve Q Posted December 11, 2017 Posted December 11, 2017 Hi Bradley, your not thinking of getting rid of the a4 now are you?! Obviously check service history, this ideally should be full and check to see if the cambelt and water pump has been changed as on the age of cars you'll be looking at, they should all be due or have had them changed. Also make sure all electronic items work as they can be expensive to fix. Are you thinking of manual or auto? And are you wanting Quattro? Cheers Steve
