Paul D d Posted December 18, 2017 Posted December 18, 2017 Hi. The oil pressure light came on the day. So I parked it up. Moved it the following day and I was then getting the turbo whistle and the the light still on. On moving the car today it has has started smoking badly. Loss of power. It's a 2.0 tdi any help on what it could be. Thanks in advance
Dan3222 Posted December 18, 2017 Posted December 18, 2017 Sounds like either the turbo or the IC (intercooler) has blown. However, if is rapidly drinking oil it pointing toward the turbo seals have gone. Is there an obviously oil deposits in the tailpipe?
Diggy98 Posted December 26, 2017 Posted December 26, 2017 Hello, Paul! The oil pressure light may be indicating a bad oil pump (probably the famous shaft if it's a 2.0 TDI). When you see the light you are supposed to stop the engine immediately and not start it again until you see a mechanic. What you have done may have damaged the turbo as it is the first part to go bad from low oil pressure...
