wire under passenger seat perished and airbag warning light has come on
So tonight the airbag warning light came on and checked around and saw this wire has perished I've taped it up now but does anyone know what the wire is for and if it would make the warning light come on?
This is quite a common fault. I believe the wire is for the seat airbag and over time it breaks which causes the airbag warning light to come on.
Obviously this will need fixing as it is an mot failure.
Steve
3 hours ago, allenby1998 said:
Do you know roughly how much?
Truthfully, no. But it shouldn't be that much as it's just the wire that needs sorting, everything else with the airbag system should be fine :)
Sorry I can't help more.
Steve
