Hi all Audiers.
Had this car for a while now and really enjoying it but it started going into limp mode the other day and I suspect the EGR valve being temperamental.
Can someone help me properly diagnose and possibly find a solution? I would not like to replace EGR if is not aboslutely necessary.
If there is any other information I can provide, please let me know. Also, sorry if I have posted in the wrong place but search returned nothing on EGR keyword.
Many thanks.
Please see logs below:
Quote
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.01.06 14:42:05 =~=~=~=~=~=~=~=~=~=~=~=
  VIN:WAUZZZ8PXBA165809  Pending DTCs ($07) ECUID:00DTCNUM:1 ISO15765-4 CAN(29bit) English
0     P0407                    Exhaust Gas Recirculation Sensor B Circuit Low
  VIN:WAUZZZ8PXBA165809  Current DTCs ($03) ECUID:00DTCNUM:1 ISO15765-4 CAN(29bit) English
  VIN:WAUZZZ8PXBA165809    ISO15765-4 CAN(11bit) English
DTC that caused required freeze frame data storage      P0407
Calculated LOAD Value                                   89.0%
Engine Coolant Temperature                              16C
Intake Manifold Absolute Pressure                       31.5
inHg
Engine RPM                                              952
/min
Vehicle Speed                                           16
km/h
Intake Air Temperature                                  10C
Air Flow Rate from Mass Air Flow Sensor                 14.58
g/s
Absolute Throttle Position                              89.0%
Time Since Engine Start                                 66
sec.
Fuel Rail Pressure                                      7247.1
psi
Commanded EGR                                           0.0%
EGR Error                                               0.0%
Barometric Pressure                                     29.4
inHg
Control module voltage                                  14.91V
Relative Throttle Position                              96.1%
Ambient air temperature                                 9C
Accelerator Pedal Position D                            41.2%
Accelerator Pedal Position E                            41.2%
Commanded Throttle Actuator Control                     95.7%
