fault code 00564
Bryan T
Hi new to this group hope i can get some help on one of the issues i have with my car which is an a6 c6 2.0tdi sline multitronic. I recently had a fault code reading and the only thing that came up was, Boost pressure Regulation Limit Exceeded (over boost condition) P0234 - intermittent. Can anyone advise me what i need to check or clean or even replace pls. tia
Z16618/P0234/000564
Contents
 [hide] 1 16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Boost Pressure too high
Reduced Power Output
Possible Causes
Hoses incorrectly connected, disconnected, blocked or leaking
Boost Pressure Control Valve (N75) faulty
Boost Pressure Sensor (G31) faulty
Turbo Charger stuck/faulty
Possible Solutions
Check Charge Pressure Control System
Perform Output Test (to check the Turbo Charger)
Perform Basic Setting (to check the Charge Pressure Control)
Perform Pressure Test to locate Leaks
Check/Replace Boost Pressure Control Valve (N75)
Check/Replace Boost Pressure Sensor (G31)
Check/Replace Turbo Charger
1 hour ago, niedzial1983 said:
Z16618/P0234/000564
Contents
1.2 Possible Causes
Possible Symptoms
Possible Causes
Possible Solutions
so in newbie plain English what do i need to do, i am very new to audi and especially diesel turbo i have always owed petrol cars and done all my own work so i am sure with the right advice i can sort the problem
