Azas Posted January 21, 2018 Posted January 21, 2018 Hi, everyone. Had my full servicing done few days ago and today I found a big colorful fluid stain on my drive. From that picture could you verify that it is oil or it could be any other fluid? Thank you
WPAWS Posted January 21, 2018 Posted January 21, 2018 i would say oil m8 but could be wrong i`m only saying it as i had a leak after my car was serviced took it back garage they sorted it out for me, turned out the washer to the sump was not seated correctly.
Azas Posted January 21, 2018 Author Posted January 21, 2018 I will give my garage a call first thing in the morning, I hope it is something simple and easily fixable
WPAWS Posted January 21, 2018 Posted January 21, 2018 On 1/21/2018 at 2:39 PM, Azas said: I will give my garage a call first thing in the morning, I hope it is something simple and easily fixable Expand i`m guessing its a simple thing like a washer its very bad luck if before the service you had no leak and now you have one if it was there before the service i would imagine the garage would have picked up on the fact you had a lot of unexplained oil under the car fingers crossed its a simple fix m8
WPAWS Posted January 22, 2018 Posted January 22, 2018 On 1/21/2018 at 2:39 PM, Azas said: I will give my garage a call first thing in the morning, I hope it is something simple and easily fixable Expand Did the garage get to the bottom of the leak ?
Azas Posted January 22, 2018 Author Posted January 22, 2018 I rang them and they booked me in for Thursday, but then I had a closer look and the fluid is clear/ yellowish so it could be brake fluid. Rang them back and they going to look at it tomorrow morning. Don't want to be driving around in a car with leaking brake fluid... I'll keep you all informed 1
niedzial1983 Posted January 22, 2018 Posted January 22, 2018 Could it be that they have spill some in the engine bay and its still dripping... Fingers crossed !
Azas Posted January 23, 2018 Author Posted January 23, 2018 Quick update, the leak has been sorted. Apparently it was leaking oil, and the reason was that the nut had wrong washer fitted so it developed a slow leak. New nut with washer installed and hopefully no more leaks.
WPAWS Posted January 23, 2018 Posted January 23, 2018 Hope that's the last of it m8, same issue i had and mine has been fine since garage put it right so fingers crossed no more oil on the drive
