Mark-Putey Posted December 13, 2017 Share Posted December 13, 2017 Hi A few months ago I needed a new battery. This was easily replaced. However I now find I've lost half the functions available eg the ride height. The car will still lower at speed but only automatically I no longer have any control over this. My trusted mechanic tells me it might have been due the the way the battery was changed and I'll need to get Audi to give (sell) me a new code to reset it. Does anyone here have any experience of this ? Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 13, 2017 Share Posted December 13, 2017 Hi Mark your mechanic is right, the battery will need coding to the car. Audi can do this or I believe it can be done if you or a friend has vag com. To be fair though, Audi shouldn't charge you too much for this. Sorry I can't help more Cheers :) Steve Quote Link to comment Share on other sites More sharing options...
Mark-Putey Posted December 15, 2017 Author Share Posted December 15, 2017 I've just been called by an Audi mechanic who tells me to disconnect the battery again (negative) wait 2 mins (without keys in ignition) then try and reconnect it without causing a spike and the system should have reset. He says the code is only for the radio and my radio doesn't have a problem. I asked him how to reconnect without causing a spike and he said touch the connection back on the battery and if you see sparks disconnect and try again, after a couple of attempts it won't spark and all will be good. This sounds a little odd to me, but maybe worth a try. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 15, 2017 Share Posted December 15, 2017 Deffo worth a try but I thought the battery needed coding. Cheers Steve Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted December 16, 2017 Share Posted December 16, 2017 There should be a code on the battery . Also codding is for battery regulator and power managment system so it knows the size voltage etc. Did you replace like for like ? Quote Link to comment Share on other sites More sharing options...
Ethan_123 Posted December 29, 2017 Share Posted December 29, 2017 Have you solved the problem?I wonder if the code could control otherthings besides radio and battery Quote Link to comment Share on other sites More sharing options...
Mark-Putey Posted January 3, 2018 Author Share Posted January 3, 2018 I replaced the battery with the one recommended for this model. I didn't notice any codes on the battery. and I don't know where these would need to be set on the car. There is no option I can see on the MMI for battery code entry. I've booked it in at Jack Barclay (HROwen) tomorrow so hopefully will have some sort of official explanation soon ... Quote Link to comment Share on other sites More sharing options...
Mark-Putey Posted January 3, 2018 Author Share Posted January 3, 2018 On 12/29/2017 at 9:07 AM, Ethan_123 said: Have you solved the problem?I wonder if the code could control otherthings besides radio and battery I have no problems with the radio. That works fine. Quote Link to comment Share on other sites More sharing options...
Mark-Putey Posted January 24, 2018 Author Share Posted January 24, 2018 On 1/3/2018 at 11:54 PM, Mark-Putey said: I replaced the battery with the one recommended for this model. I didn't notice any codes on the battery. and I don't know where these would need to be set on the car. There is no option I can see on the MMI for battery code entry. I've booked it in at Jack Barclay (HROwen) tomorrow so hopefully will have some sort of official explanation soon ... They fixed it for £60 So I was very pleased (and a little surprised). Quote Link to comment Share on other sites More sharing options...
